Old 04-26-2009, 07:05 PM
RoninKS RoninKS is offline
Default Putting fluid in tires
What's the best method for putting windshield wiper fluid in rear tires?
Old 04-26-2009, 07:18 PM
If you can wait a couple of days until I get home, I'll post a picture of my setup...
Old 04-26-2009, 09:07 PM
CBH's Avatar
CBH CBH is offline
The best method?
Well, I just got a set filled at a local tire shop for $10 per tire.
That's the best method that I've found! :biggrin2.gif:
Old 04-26-2009, 11:24 PM
CBH,.... LOL, yeah that's a pretty good method alright. The nearest place I can get it done (at a tire shop) is over 30 miles away.
Question,... did they pump the fluid into your tires??
I don't have a way of doing that, but I do have a tire machine and I've thought about "breaking" the bead on one side of a mounted tire and just pouring the fluid in, then airing the tire back up and re-seating the bead.
Old 04-27-2009, 12:44 AM
Trust me, you want tubes in your tires if you are going to put fluid in them. I speak from experience...
Old 04-27-2009, 01:29 AM
UH OH!!!!,... I don't have tubes in my tires.
Do the tires leak fluid without tubes??
Old 04-27-2009, 09:34 AM
Not normally...but I knocked a tire off the rim plowing snow with my 128 at a friend's house...6 gallons of washer fluid is a mess. At least it melted all the snow out of their driveway. :biggrin2.gif: I had to walk home and drag another tire and tools with me, pull the weights off, change the tire, and put the weights back on. It was annoying. I will never put fluid in tubeless tires again. Somewhere, I have a picture of this incident, but I can't find it...
Old 04-27-2009, 09:57 AM
CBH's Avatar
CBH CBH is offline
They used an air operated pump to put the windshield washer fluid in the tires. It just hooked right to the valve.
I guess that I'm lucky. I have 3 sets of loaded tubeless tires, I've not had any troubles...........so far.
Old 04-27-2009, 12:51 PM
Originally Posted by CBH View Post
The best method?
CBH,... did the $10 per tire include the cost of the fluid?
.... if so, that sounds like a REAL good deal.
Old 04-27-2009, 04:31 PM
CBH's Avatar
CBH CBH is offline
Yes.....labor and fluid, $10 per tire.
