my 1864 red charge light comes on when I activate the electric clutch to mow.
The light only comes on when I engage blades. Can anyone tell me what might be wrong? Thanks !! |
First, welcome to OCC.....
![]() Do you have a DVM or VOM...??
I can only guess where Roland is going on this one but if you have a multimeter/voltmeter, start your machine, engage the PTO, then take it to WOT. Check the voltage at your battery posts. It should be 13.6+ (at least). If it's not, then I'd bet it's your rectifier, maybe something else. Good luck
-Ryan
![]() Quote:
Poolenglish, your 1864 should have a Kohler Command in it if it is original. You can download the service manual here in the tech section to help with your troubleshooting. Good luck and welcome to OCC!
I mixed up the one that has the problem is the 1862. I have 4 cubs; 2- 1862's with magnum (horizontal opposed) engines and 2- 1864's with command (v twin) engines. |
Check the voltage at the battery. Those lights are notorious for giving a false indication. Pic is my answer to the problem. I like knowing what is truly going on. These are on my 1782 but I also have them on my other Cyclops.
That Sunpro mini triple gauge set (with black faces) is currently on sale for $16.99 at Advance Auto, not a bad deal.
Sam, Aren't those gauges all mechanical? How did you install the temp gauge into the engine? I looked at mine, don't seem to be anywhere to install that big sender bulb.
982D kwik-way loader w/3 spool control and front and rear remotes,2182, 1812 cat 0, 1440 puller, 3185 grass killer, 2x 450s, QA42, 364, tiller |
