Old 10-23-2014, 11:52 PM
thadscub's Avatar
thadscub thadscub is offline
Default Torquing rear wheel bolts
i was wondering if their is a toqrque spec for the rear lug bolts i have always have just put them on as tight as i can with a rathchet and socket
thanks thad
Old 10-24-2014, 12:23 AM
Your doing it right.
Old 10-24-2014, 01:05 AM
jcsmith jcsmith is offline
Officially 60ft/lbs, but common sense tight like you're doing is standard practice.
Unless you're a he-man and don't know your own strength , then torque 'em.lol
Chris
1968 104 , service replacement '96 K301, 42" deck
1997 Scotts 42502X8 , repowered with '96 B&S 18hp TwinII , 42" deck
2007 LA130,21hp Intek v-twin, 48" deck
As you slide down the banister of Life, may the splinters point in the right direction .
Old 10-24-2014, 07:47 AM
jeepchicken5000's Avatar
I use my battery impact drive when it stops there on but its only I think 900 inch pounds or so and its always takin off the lugs on the tractors so must be just right.
1981 cub cadet 682
1966 cub cadet 122
Old 10-24-2014, 08:42 AM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
Chris
Or you weigh 300lbs and are lifting yourself off the floor when tightening them.
Old 10-24-2014, 10:08 AM
jimbob200521's Avatar
Lately I've been using my impact on its lowest setting, not sure what it exactly is. It's rated for 600ft/lbs I believe so whatever setting 1 of 3 is I just hand tighten then, then give them a couple bumps with the impact until it stops spinning. No wheels have fallen off so far or broken lugs
But in the before times, I'd use a 3/8 or 1/2 socket and tighten them up until they wouldn't go anymore without getting unreasonable with the force.
-Ryan
Old 10-24-2014, 11:08 AM
rwairforce rwairforce is offline
Even if a wheel would fall off it would most likely be more humorous than dangerous....unless you have a turbo charged engine and mow at 20mph...
Randy
Cubs: 71, 72, 127, 149, 1440, 2186 and 1864
John Deere 110 round fender
John Deere 140 H3
Sears: GTV16
Old 10-24-2014, 05:06 PM
I get mine (with a socket/socket wrench) somewhere between snug and red faced grunt tight.
Old 10-24-2014, 05:52 PM
Mine go on just snug plus about an 1/8 of a turn with a 3/8" ratchet.
All you need to do is deflect the center of the wheel to keep tension on the nuts to keep them from backing off.
