Old 10-21-2014, 09:28 AM
Steve149's Avatar
Steve149 Steve149 is offline
Default Exhaust Question
Sawdustdad I borrowed your picture for this cause it shows what my question involves.
Isn't the lock ring on the stub (Red Arrow) supposed to be locked against the casting? I noticed mine wasn't and the whole muffler assembly is loose...would explain the rattling noise I hear when it is running!
Old 10-21-2014, 10:01 AM
yes, that is the lock, usually tightened against the head using a chisel or punch.
Old 10-21-2014, 10:03 AM
Steve149's Avatar
that is what I thought just wanted to make sure...looks like a job for PB Blaster again!
Thanks man!!!
Old 10-22-2014, 09:40 AM
Steve149's Avatar
Is there anything more to the clamp holding the muffler to the stub? Or is this like a typical muffler clamp?
Old 10-22-2014, 11:12 AM
it is like regular clamp, I was able to re-use mine, but I replaced the bolt and nut.
That one on there is correct. The heat shield has a bolt hole to help stiffen the other end.
Old 10-22-2014, 12:42 PM
Steve149's Avatar
Any chance you know the size of that clamp bolt off the top of your head...Im at work and could pick one up at lunch!
Old 10-22-2014, 01:07 PM
5/16x18 carriage bolt, seems like it was 1 1/4" or 1 1/2" long IIRC.
Old 10-22-2014, 02:05 PM
TheSaturnV's Avatar
I suggest a stainless steel bolt/nut. ACE Hardware has the right size for the muffler bracket.
Old 10-22-2014, 02:07 PM
Steve149's Avatar
Yes the one that is on it now is rusted up pretty bad..it is soaking in PB Blaster now soo hopefully it will come lose with out any issue!
