I've taken my gas tank down to the metal and it looks great. Should be a really nice paint job if I can take my time and do this correctly
Seems like I have some rust in the tank and I have read that apple vinegar can clean that right up. Is this a good idea for our tanks? I was not sure if the tank had a lining that the vinegar would hurt.
108 upgraded to 12hp 127 with all the trimmings 73 WIP 75 WIP Blade, blower, decks Tons of left over parts
Alternatively, a salt and vinegar mixture can be used as these ingredients will react to form a weak sodium acetate and hydrochloric acid solution. This solution should remove rust more quickly than the acetic acid in vinegar alone.
Patience is the key to success . The difficult, I'll do today . The impossible, I'll do tomorrow
I was only going to clean with the vinegar but was wondering what to do next. This guide should help a lot
Your welcome. If it is going to be a while before you use it, put some premix (like what you use in a 2 cycle engine) in and slosh it around in the tank. This will help prevent rust till you use the tank.
I've used CLR on a few tanks with surface rust and it worked great. I fill it 1/3 , shake it a bit, then let it sit. Every so often, ( depending on severity of rust) turn tank to a new position. I did mine for 1 week like this, looks brand new. You could put small nuts and bolts, or aquarium gravel in to help scrubbing action.
Just remember the baffle in the tank. If anything solid gets behind it ,it may not come out. I used CLR only for this reason. If you have calcium , lime , or rust in your water, dump it down the sink or "terlet", your choice. Then rinse as above, should be good to go. Have fun. Chris
1968 104 , service replacement '96 K301, 42" deck 1997 Scotts 42502X8 , repowered with '96 B&S 18hp TwinII , 42" deck 2007 LA130,21hp Intek v-twin, 48" deck As you slide down the banister of Life, may the splinters point in the right direction .
I used CLR and hex nuts (easy to remove with a magnet). Strapped it to my cement mixer. Ran the cement mixer for an hour a couple times over the next few days. Neutralized with baking soda. Sealed it with a product called 'Red-Kote'. Turned out perfect.
Tank and straps came out really nice.
That is a shiny tank,did you tank everyone for their advice?
Ugh! Hahaha thanks for the info :-)
