Old 10-16-2014, 10:24 PM
jeepchicken5000's Avatar
pretty much done need a choke cable and a clutch hoop cover , some reflectors would be good or tail light even .
1981 cub cadet 682
1966 cub cadet 122
Old 10-16-2014, 10:59 PM
Looks great Mr. Chicken. Quality work and very fast. You still using the majic paint? I mixed mine 4:1:1. Can you elaborate how you mix yours? Do you use the hardener? Or clear afterwards?
Old 10-17-2014, 07:25 AM
Looks great.
Old 10-17-2014, 08:06 AM
I still use majic paint, I did go over to the school bus yellow in a gallon, its the same as cub cadet yellow but you need to buy cub cadet yellow spray cans because school bus cans are the wrong color. I mix my majic paint when doing a hopper ful 16 ounces paint 2 ounces reducer and 3 caps full of hardener idk what that comes out to be but it always works great and I can assemble next days for my majical restorations . now what do you guys use for primer, you have to have a good base for the paint I always use rustoleum white primer never failed me and works great gives a nice true color , don't spray this paint over none primed surfaces it wont come out that good .
1981 cub cadet 682
1966 cub cadet 122
Old 10-17-2014, 06:31 PM
I used school bus yellow in the gallon, and you're right, the spray can school bus yellow comes out very dull, seems cub cadet yellow is much brighter.
Old 10-17-2014, 08:02 PM
put her to work today did pretty good but I need to get a choke cable and throttle cable since I don't have a choke and throttle don't have enough travel to work the carb, its not a cub cadet throttle cable. other then that it did great looks great matches my 102 nice ill pos a pic in the pictures thread
1981 cub cadet 682
1966 cub cadet 122
Old 10-17-2014, 08:25 PM
you don't f around when it comes to painting and restoring these.Nice work
Old 10-17-2014, 08:41 PM
nope my schedule is I have to have them done in as little time as I can , never know who needs the garage would have been an extra day if I had to work but 3 days is good about the quickest I can do think my 70 was the same
1981 cub cadet 682
1966 cub cadet 122
Old 10-17-2014, 09:08 PM
Btw unless my eyes deceive me you used a more correct white for this model instead of the "IH white" that you spoke about and used on the others. Can you tell us what white you used? Again, like everyone else says, you really did a fine job.
Old 10-17-2014, 09:13 PM
I used IH white I don't change paint except I went to the school bus yellow but no one would notice the difference
1981 cub cadet 682
1966 cub cadet 122
