Old 10-14-2014, 05:20 PM
larryp larryp is offline
Default hard pin
I have been beating on that pin and it wont move, guess I will try to drill it out , not having fun at all. Larryp
Old 10-14-2014, 05:25 PM
They're hard. Doubt you can drill it. Not without going through a ton of bits anyway. I'd say it's bent and that's why it won't budge. Good luck, that's never fun.
Old 10-14-2014, 11:08 PM
If the pin is sheared and the three holes are not lined up, you will NEVER be able to beat the pin out.
You're gonna have to get that arm lined up the same as the other one and THEN knock the pin out.
Old 10-15-2014, 06:04 AM
Old 10-15-2014, 08:06 AM
Default bent pin
Thanks, i will give that a try, if my arm will last
Old 10-15-2014, 09:23 AM
Use a floor jack to push the "lower arm" up to match the other.
Old 10-15-2014, 12:06 PM
Default pin removel
Well i removed the pin, took about 1min then i got the cub where i could hit the pin, the pin was not bent so i turned it around and drove it back in, seemed to help, i will know more when i re-attach the deck, i was feeling good about then, when i let the cub down, and saw i had forgoten to remove the BATT, yea your guessed it, new paint has streaks, no easy job will go unpunished, larryp
Old 10-15-2014, 01:09 PM
Glad you got it out, sorry about the paint.
Old 10-16-2014, 01:03 PM
Default wrong pin
put the deck on, still low, i will remove the other pin next, not having fun yet
Old 10-16-2014, 01:20 PM
Take the battery out this time......
