Old 09-28-2014, 11:05 PM
HoundDog's Avatar
HoundDog HoundDog is offline
Does anyone know where I can get that "rubber bushing" that mounts to the dash that holds the steering column centered in the dash? It's just below the steering wheel.
Restored 1970 127
1962 Original
Old 09-29-2014, 12:50 AM
Place a wanted add or one of the sponsors may have one. I placed a wanted add and got mine a couple years ago from a member. Good luck
Old 09-29-2014, 09:59 AM
HoundDog's Avatar
Thanks, Zippy. Did I call it the right name? I'd hate to post a wanted add and call it the wrong thing and throw people off...
Restored 1970 127
1962 Original
Old 09-29-2014, 10:40 AM
HoundDog's Avatar
Another question:
What size are the front wheel bearings/bushings in my 127 and my Original?
I can't find the info.
Restored 1970 127
1962 Original
Old 10-04-2014, 10:32 AM
HoundDog's Avatar
Got it back together last night and it fired right up instantly! I guess I had the carb settings right for start up.
Only bad thing is that the sediment bowl is leaking where the fuel on/off threaded deal threads into the casting. Now, I'm on the search for a new shaft gasket.....
Restored 1970 127
1962 Original
Old 10-05-2014, 08:54 AM
jbrewer's Avatar
jbrewer jbrewer is offline
Default Congrats
Leaks in the sediment bowl and around the fittings are a perpetual issue for "O" owners. They can be overcome but it's a common problem.
You've got a really nice O...they're strong and sturdy little tractors.
I got the gaskets for the steering col and dash off of Ebay.... there's probably still a seller there with them. On the other hand I never gor the *$)#*$ steering wheel to come off so I still have that part!
John
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 10-05-2014, 09:28 AM
Diesel Krazy's Avatar
Diesel Krazy Diesel Krazy is offline
Napa sells a complete replacement sediment bowl and had it in stock when I got mine a few months ago. It was an exact replacement and I believe it was under $20. It fit perfect and looks original.
Original- Wheel Weights, AG tires, Brinly Sleeve Hitch, #2 Cart
882- 50c Mower Deck
2182- 60c Mower Deck, Rear PTO, Cat 0 3-Point, Brinly 60" rear blade
Case 646 FEL
Case 446
Old 10-06-2014, 01:32 AM
HoundDog's Avatar
Thanks, guys.
I found a column grommet from a member here. It should be here in the next day or 2.
I did get the sediment bowl to stop leaking, but now the nipple that's in the bottom of the fuel tank is leaking where it goes into the tank. I haven't looked at it too much (other things I had to do). But, so far, without much investigation, I don't know if it's threaded into the tank, or if it's pressed in. Hopefully, it's threaded in. If so, I can fix it.
Restored 1970 127
1962 Original
Old 10-06-2014, 07:33 AM
jbrewer's Avatar
I believe they're soldered into the tank, but I can't say for sure. The one's I've worked on were soldered at the point I got them.
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
Old 10-06-2014, 10:55 AM
Yes it's soldered. I had to repair mine it had a small crack in the old solder.
882- 50c Mower Deck
Case 646 FEL
Case 446
