Old 09-30-2014, 11:55 PM
All the comments on here are good.
Steve, if it's worn like you say it is, I'd rebuild it. Or replace it. Whatever works best for you. I do both. Just depends on how bad it is. I'm not opposed to new parts, or fixing old. That they end up nice and tight is the important part. Ryan's idea with the shim works...... temporarily. No matter how you fix it, remember this. It's a 40 year old machine with more than likely original parts. If you use original, or rebuild to those original specs, it should by all rights last another 40. Will you care by then?
Old 10-01-2014, 09:24 AM
sawdustdad's Avatar
I've found that new springs help a bunch, too, to improve speed control.
Old 10-01-2014, 10:31 AM
Steve149's Avatar
Steve149 Steve149 is offline
I heard that!!!
Old 10-01-2014, 11:52 AM
Steve149's Avatar
I am all for rebuilding it most of the parts are available with the exception of a spacer .406x.68x.83 part no. IH-279783-R1 says it needs 2 of them...it isn't on the diagram where do they go and are they steel spacers or what???
