Old 09-15-2014, 11:38 PM
Merk Merk is offline
Your serial number is on the reduction housing.
The serial number on this housing is 89482.
Project Uncle Dick
Cub Cadet 70
Old 09-16-2014, 09:15 PM
jeepchicken5000's Avatar
ok serial is 69994 so its a December of 63 from what im seeing I thought it was a 64 so I was close
1981 cub cadet 682
1966 cub cadet 122
Old 09-19-2014, 07:46 AM
hey guys after looking at the 70 for a little bit the shifter seems longer then it should or were they also that way ?, also second seems slow compared to my 102 would take a longtime to mow the lawn id imagine
1981 cub cadet 682
1966 cub cadet 122
Old 09-19-2014, 10:43 AM
I also agree the shifter looks way to long, kinda looks like a wide frame shifter with the end cut off or straightened.
Old 09-21-2014, 08:56 PM
well guys getting started soon on the 70 I picked up some wheel barrow tires to put on the front rims, there rated for 330 pounds each so they should work, ive used them on lawn carts before they seem fine, anyone against these ?
1981 cub cadet 682
1966 cub cadet 122
Old 09-21-2014, 09:23 PM
You have the right shifter,just used what they have on the shelf,second gear is slower,as they used a the same gearing as an original up to a certain serial #92325 I believe
My 100 has the faster second,seems too fast to mow with...
Old 09-21-2014, 09:28 PM
The early 70/100s has a 16 tooth 2nd gear. Speed is 2.9 mph.
Your 102 has a 19 tooth 2nd gear. Speed is 3.9 mph.
Note: engine is running 3600 rpm.
Can you post a picture of the shifter?
Project Uncle Dick
Cub Cadet 70
Old 09-21-2014, 09:47 PM
hows this looked at it for 30 seconds and oh its just pushed on and I yanked it off with pliers , so the question is the knob should look like my 102 right ?
1981 cub cadet 682
1966 cub cadet 122
Old 09-22-2014, 10:18 AM
Hey guys orders a few parts for the 70 and noticed it has a kohler k181 in it so that's the 8 hp engine looks like I got more power haha
1981 cub cadet 682
1966 cub cadet 122
Old 09-23-2014, 10:45 PM
got started today on the 70 got real far don't take long to do bout 4 hours for today
1981 cub cadet 682
1966 cub cadet 122
