Old 04-25-2009, 07:50 PM
RoninKS RoninKS is offline
Default Dual wheels
Question for ACecil and others that have dual wheels on their cadets,... do your dual wheels interfere with the small wheels on your mower deck????
I'd like to put dual wheels on my CC100, for more stability on sidehills when mowing.
Thanks,
RoninKS
Old 04-25-2009, 10:12 PM
Ron,
I have no idea, about the duals interfering with the mowing deck's wheels. I don't have a deck for my 100. The duals will definitely give you more stability on the hills.
Old 04-25-2009, 10:17 PM
I am willing to bet that the duals would interfere with the gauge wheels on the deck.
Old 04-25-2009, 11:49 PM
Depending on the deck that you have, I'm thinking that the gauge wheel will fit right in between the duels. The duels will mash the grass down before it gets cut and you may end up with a not so neat looking lawn.
I mow about 400 yards of highway ditches here and some of it is pretty steep. I pull a 60" drag behind mower with my 109 making my cutting swath nearly nine feet, so I weighted 1 rear wheel for extra traction on the up-hill side, otherwise there are places where I would just sit and spin.
Old 04-26-2009, 12:08 AM
Yeah,... I'm thinking the same thing, UNLESS someone has had a different experience.
Old 04-26-2009, 09:23 AM
Yeah, that might work until you bump something with the deck and the gauge wheel digs into one of the tires. Besides, with most dual wheel adapters, the wheels are less than an inch apart.
Old 04-26-2009, 12:43 PM
Thanks,... I was wondering about the spacing between the duals and if there was actually enough room for the deck's gauge wheels to clear the outside tires.
Old 04-26-2009, 02:19 PM
CBH's Avatar
CBH CBH is offline
Here is a picture of my 128 with Craftsman wheel weights. Because they stick out a couple of inches, I could not use these weights on the 1650 because they would hit the mower decks wheel brackets. Although they will work fine on the 128, there was no way that I could have run dual wheels on the 1650 !
