So now that I finally have my 108 running I find no better way to relax after a long day but to do a few victory laps around the property
108 upgraded to 12hp 127 with all the trimmings 73 WIP 75 WIP Blade, blower, decks Tons of left over parts ![]() |
Under the hood on the dash there should be a piece that held on by 2 bolts, it should be adjusted up enough that the hood is resting on it and not the dash. I also put black door edge guard on the piece which makes the hood fit snug and eliminates 99% vibration your hearing.
![]() Quote:
Here's a pic. If the hoods resting on this and the hold downs are tight you should be pretty good.
The rubber covers on those flanges are all worn off mine. Before I start trying things is this something still available?
Not sure I understand your question. The rubber your seeing in the pic is the door edge guard, you can get it at any parts store.
Haha I was thinking something totally different :-) Ok cool and thanks.
No problem
You got a single cylinder Kohler. Those things make any cub shake rattle and roll. Hope you can get it tightened down.
1977 1650 with cast iron lower grill housing, cast iron oil pan, 54" push-snow blade, rear blade, disc-harrow, 44c and 48" decks, Two cultivators, #1 tiller with both extensions, loaded tires, 75' weights and chains, #2 cart. |
