Old 09-10-2014, 09:29 AM
steved steved is offline
Default 105 Throttle/Governor Setup
I recently replaced the governor spring on my 105 and I cannot get the throttle cable set right. It is the correct P/N ordered from Cub Cadet but it must be a little longer. When I pull the throttle handle to idle, the engine is still running fast. If I move the governor arm to the right with my finger it idles down and is fine. In the picture the spring is not in the factory position. This me trying different settings. I have set the governor arm's position per the manual. I cannot find anything about setting the throttle cable in relation to the spring and pivot plate in between them. Do I need to re-set the throttle cable? Thanks for your help.
Old 09-10-2014, 11:01 AM
My first question has to be: Why did you feel that the spring needed to be replaced?
Does it feel like the governor is actually working?
When the throttle is pulled all the way back there should be no tension on the spring.
Old 09-10-2014, 12:14 PM
1. When the engine was idling the spring was flopping around. At the time
I was ordering some other parts and felt it would be good to replace.
2. Yes, I believe the governor is working.
Do I need to adjust the throttle cable?
Old 09-10-2014, 01:30 PM
Just loosen the throttle cable up in the clamp and re-position it so it works. The spring SHOULD "flop around" at idle. Now, you are going to have to reset the High-idle, no load too. You will need a tach to do this. Either a photo-tach, or one that works off of the ignition system. Some timing lights have this feature.
Old 09-10-2014, 03:18 PM
Thanks for the info. Can you point me to the section in the manual or another thread that might help. I've never used a tach light. I see the "Ignition Timing" on page 1-33. There doesn't seem to be all the info I need to do this. When you say High-idle, no load, are you talking about the carburator settings?
Thanks again.
Old 09-10-2014, 03:43 PM
High-idle, no-load is a governor setting. It will be in the governor section. Start with adjusting the governor "Initial settings" and go from there. Page 6.29-6.32. Read it all, then do it.
Here is an article on setting timing.
http://www.onlycubcadets.net/forum/s...ad.php?t=33461
Old 09-10-2014, 03:54 PM
The article on the timing looks great! On the governor, I must be in the wrong manual. What I'm looking at only has 3 sections, no number 6. I'm looking at the 1x4-5 service manual. Help?
Old 09-10-2014, 03:57 PM
Kohler "K" series service manual.
http://www.onlycubcadets.net/forum/s...ead.php?t=4646
Old 09-10-2014, 04:26 PM
Thanks, disregard the last message. I hit resend. I'll check out the engine manual. That's what I've been missing!
Old 09-11-2014, 08:33 AM
J-Mech, while I'm getting ready to set the timing, would it be a good idea to change the points? I would bet they are the originals from 1969. If so, where would you suggest to buy them? I've bought everything in the past from the MTD/Cubcadet website. Thanks again.
