Old 09-10-2014, 09:30 AM
Dave_With_Cub108 Dave_With_Cub108 is offline
Default Cub 108 Brake Caliper Assembly
Thank you for the instructions on the Cub 108 brake caliper assembly. As you say, I should use the shoulder bolts that are designed for the caliper. Where I went wrong is when I replaced the original should bolts with the incorrect type. I did this thinking that the original bolt nuts were worn.
Now, I know what to do to complete the brake pad replacement.
Thanks again!
