I was able to get up underneath of the wheel with a puller and with some light tapping I finally was able to coax it off.
Good to hear. in the future another good way to get a wheel off that's really stuck is to remove the nut and spray it with pb and then go now the grass, I've only every had to use that method once on a 122 wheel that just wouldn't come off but after an hour of mowing it popped right off.
I've heard of guys having luck using an air chisel with a round punch attachment to hit the loosened nut while putting upward pressure on the wheel with your knees.
Adam 1964 Model 100 w/ K301 12hp and custom hydraulics 1972 Model 149 turned 129 w/ K301 12hp, triple hydraulics, 66 series clone |
That is the way I do it.One thing about those type of steering wheels you can fill it up and not make a mess on the dash tower.
