Old 08-25-2014, 08:34 PM
I'm not sure what that is because it has a lot of wrong stuff on it but those 10 bolt K341's bring big $. Cool find.
Old 08-25-2014, 08:50 PM
It has the wrong air cleaner and muffler for a 169
ford4150's Avatar
ford4150 ford4150 is offline
Ported hydro pump w/o hydro lift on this one.
Old 08-25-2014, 08:57 PM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
My 169 is also a ported pump without the hydraulic lift option. My 149 does, however, have the hydraulic lift. If I get the time to restore the 169 it will have the optional hydraulic lift installed.
Queen Of The Quietlines!
Old 08-25-2014, 09:21 PM
Standard lift on the 149 and 169 was the hydro lift.
IH ran out of hydro lifts during the production run of the 169 so they installed the ported hydro pump. The owner of a 169 could purchase the hydro lift later on.
Parts book shows hydraulic lift optional for all 1X9's. I loaned my "book" out to my bro, who has yet to return it (FlyingB ) or I'd know for sure. I will say it's a rare thing that the parts book would be that far off. I'm sure this info is correct.
To the OP:
If it is a 169, it's either been pieced together, or it's a 149. It's missing all the parts for a 169. You sure your looking in the right spot for the SN?
Old 08-25-2014, 10:01 PM
Merk Merk is offline
To the OP:
My information came from Hank Wills Cub Cadet The First 45 Years
Look on page 61 if you have the book.
Model 149 info says the 149 had hydraulic lift as standard equipment.
Model 169 states the following
from Hank Will Cub Cadet First 45 Years
although hydraulic lift was "standard" equipment , many were sold with the hand lift because of a shortage of valves; all were delivered with a ported hydrostatic pump so that the hydraulic lift could be dealer installed later; machine code is 0048
The hydraulic lift was an option for the 109 and 129.
Project Uncle Dick
Cub Cadet 70
Old 08-25-2014, 10:05 PM
ford4150's Avatar
I admit to being new to Cub Cadets. Pretty sure this is where it's supposed to be:
At least the motor has a 10 bolt head, so I'm pretty sure it's a K341. I can read K341A on the decal, but not the serial number.
Old 08-25-2014, 10:12 PM
I agree!
I wasn't debating the info, I was just stating that hydraulic lift was optional for all.
Old 08-25-2014, 10:55 PM
JLM78 JLM78 is offline
169s only had the serial on the left side on the frame not on the rear end
Old 08-25-2014, 11:49 PM
ford4150's Avatar
I guess that settles it; there's nothing on the left side of the frame.
