Old 08-22-2014, 12:20 AM
If you have around 13.VDC at 3600 Engine RPM's, then this is NORMAL.
Agreed.
But, it should start charging before half throttle. Also, it shouldn't creep up slowly. My guess is failing regulator.
Run it at half throttle and ground the "F" terminal and see what it puts out. Should be really close to 13V even at half throttle.
Old 08-23-2014, 02:27 PM
Diesel Krazy's Avatar
Diesel Krazy Diesel Krazy is offline
Agreed.
That F terminal test failed so I brought the starter generator to my starter repair guy and he tested it with his tester and it failed so it's getting repaired as I type this. He said to bring the regulator in when I pick up the S/G and he will test it also. Hopefully in an hour or so it should be back together in time for my daughters evening drive with the dog in the trailer.
Original- Wheel Weights, AG tires, Brinly Sleeve Hitch, #2 Cart
882- 50c Mower Deck
2182- 60c Mower Deck, Rear PTO, Cat 0 3-Point, Brinly 60" rear blade
Case 646 FEL
Case 446
Old 08-23-2014, 03:05 PM
Let us know what he found. I've had a few with open field coils. You can fix it yourself and save some $, not much inside them and easy to take apart.
Old 08-24-2014, 05:37 PM
I finally got my S/G back from my rebuilder. He said it was a bad armature. So it got a new armature, two new bearings, new brushes and he tested my existing voltage regulator. It cost $97.00, not a cheap repair. On his home maid load tester he spun it up and it was puting out 12 amps at aprox 1800 rpm as I watched. Before his repair work it was putting out 1 amp. Right now it's getting a quick coat of Federal Yellow and when it's dry enough it's going back on. Hopefully in time for my daughters evening drive with the dog in the trailer. Thanks for the help as always.
882- 50c Mower Deck
Case 646 FEL
Case 446
Old 08-24-2014, 06:26 PM
Paint is a bit sticky yet but I got the regulator and S/G back on and it works great. Did a quick check and at aprox half throttle there was 13.2v. When I get things cleaned up I will do a full throttle test, I'm sure it will put out what it should. I never should have painted the S/G and bracket, the bright new paint may become contagious.
882- 50c Mower Deck
Case 646 FEL
Case 446
