Old 04-22-2009, 08:31 PM
zekepiks zekepiks is offline
Default drive shafts
Hello, I need some help, I need to replace the drive shaft on my 108 and I've been looking on e-bay and I see one that will fit a 73, a 107, or a 127 and while I think they are all narrow frame tractors I didn't know if there was a difference in the length between the engine and rearend on wide frame or narrow frame tractors, If this won't work could someone tell me what ones will fit, I need to remove the creeper drive is why I need the longer shaft. Thanks, zekepiks
Old 04-22-2009, 09:27 PM
Carolina Cubber's Avatar
Carolina Cubber Carolina Cubber is offline
Check this out. It's all you need to know about driveshafts.
Old 04-22-2009, 10:23 PM
If you have a drill press, you can make a new driveshaft yourself. They are just a piece of 5/8" cold-rolled steel. I'd be a bit wary of buying used driveshafts...they wear out. You'll need one from an 86, 108, or 128.
If you make your own, be a bit careful with the measurements in the link Carolina Cubber posted...they are not quite accurate.
Old 04-22-2009, 10:39 PM
Before i had a mill to make my own, i bought drive shafts from Brian Miller
with no problems with fit whatsoever.
Old 04-22-2009, 10:47 PM
To be more specific, the roll pin holes for the two pressure plates were probably 40-50 thou too close in my opinion...when I built the clutch for my 582 with those numbers, I had difficulty assembling it because of this. It isn't a problem if you have the pressure plates turned because they will be thinner, but I installed a set that I hadn't turned and had some trouble. The next driveshaft I made, I added some to the distance between those two holes, and it worked fine.
Old 04-23-2009, 05:28 PM
Yeah, if it were mine I would make my own or get one from Brian Miller, and if you don't have access to a lathe send him your plates and have him true them up. For about $30.00 plus shipping, you can have all the work done that you need. Changing the disk is your option, I think a kit is about $50.00.
If you buy a used one on epay, it's still just an old used clutch and shaft and you're most likely going to have to do or have all this work done anyway.
Old 04-23-2009, 07:49 PM
Default many thanks
I just wanted to thank all of the forum members who took the time to reply to my questions,I'm a lead worker on a bridge crew for the state of michigan and we have just started our bridge repair season so some times when I post a question it may be a few days before I get back to view it or to reply, but again Thanks
