Ok, have done some looking, and have found a 2185@ $1350.00 295 hrs, and a 2186 $450.00 unknown hrs. The 2185 pricey to be a parts donor. Will be looking at the 2186 this afternoon. It is running and cutting. So Sam I'll be in touch.
I agree the 2185 is way high, I hope that you can get a little better price on the 2186.
put the Mag back together, get it to start, tie a string to the gov and pull and watch the fun happen. then repower. lol
we do the string to the governor linkage thing all the time to Tecumseh junk engines that are going to scrap anyway. its fun!
Cubs: 2072 w/60" Haban, 782 w/Johnson 14 loader & 44" deck, & 169. Others: Ford 120, Ford LGT100, Ford LGT125, 2 - Ford LGT145s, & 4 - John Deere 140, H1 and H3. |
Need a vid of the parts flying!
Going to try to save the m18. Cleaned up the pump and rear to see where that is. After I got it cleaned up, I put a drill to it. Hydro works axles turn steering deck lift all work. But there is a leak at one of the check valves? Sprays out pretty good. There is also a splinded shaft at the rear of the pump. Was a rear PTO an option for the 1862? Frame is in pretty good condition, so may just repower. The tractor I went to look at was I think a 2135? Had a 12hp.
No rear PTO on the 1862, just a common shaft on the pump.
Are the check valves serviceable? What would cause it to leak. From what I can tell that's the only leak.
Machtech Direct 605 Furnace Rd. Conneaut Ohio 44030 Phone: 440-499-5813 Email: mark.machtech@gmail.com E-Bay add $35.00 each plus $4.95 shipping ($4.95 flat rate regardless of amount) That's both valves rebuilt for only $74.95
I had an old-timer tell me he had a trick to clean the aluminum off of the crank journals. He would go to the hardware store for some muratic acid that is used for masonry jobs. Dip the crank journal in it and let the aluminum dissolve. A slight polishing was usually the only thing that was needed to clean up the journal afterwards
1989 - Cub Cadet 1772 1987 - Cub Cadet 1572 w/Rear PTO & Cat. 0 38" Lawn Sweeper #196483 42" L42 (Bush Hog) Rotary Cutter # 190349 45" 2-Stage Snowblower # 196364 48" Haban Rotortiller Rear PTO Driven #190356 54" SnowBlade with hydraulic Angle #196376 60" Haban Mowing Deck #196374 |
