Old 07-20-2014, 02:57 PM
Originally Posted by SS5150 View Post
.....had an odd muffled sound kind of like an exhaust leak.
.......and I think the front seal is bad, as I have oil slung around the inside of the exhaust tinwork in line with the PTO.
It's a tough sound to describe, just doesn't seem to have as hard of a 'hit' as when a rod bearing goes out on an automotive engine.
You may have a crank seal leaking, oil sending unit or oil filter hose leaking. Or..............?
Others interpreted your "noise" description as a "knock". I will interpret it as a blown head gasket.
I have spent quite a bit of time riding on the rear fender of a Cyclops to keep it from tipping/spinning, running along the side of a hill and I've never had any problem with starving the M 18, CH 18 or Vanguard 16 for oil. That's not to say you can't.
Old 07-20-2014, 05:51 PM
bill682 bill682 is offline
I have had to replace that seal more than once. I don't know if it's a heat issue or a sudden jolt or what but they don't seem to last. Last time I replaced it with a SKF 13734 and I have had no problems. I don't think the seal Kohler provides is good and may be why so many KT and Mag twins blow.
http://www.napaonline.com/Catalog/Ca...734_0349835347
Old 07-20-2014, 06:01 PM
SS5150's Avatar
SS5150 SS5150 is offline
You know, the blown headgasket might be something. I noticed when I pulled the exhaust & pto off that the left bank was white in the ex manifold. The front crank seal was definitely the oil leak, I was able to move it around and spin it by hand. Ended up fishing it out with a small pick tool. Fortunately my Cub dealer had a seal in stock. Anyhow I nailed it together, made sure oil was full and fired it up. Doesn't seem as loud today. I think I'm going to pull the tin off the left head though. Thanks for the ideas everyone. I really enjoy this forum.
RUN IN THE RED
1872 project
Cub Cadet Pro Z 560 L
Old 07-20-2014, 06:15 PM
gsomersjr's Avatar
gsomersjr gsomersjr is offline
I'm thinking ditch mowin could be hard on these engines if it was low on oil and the pump pick-up was on the high side. See if you can put an oil pressure gauge on it so it wont happed again. I hope its okay.
Another option, or in addition to a gauge, might be an idiot light. I mow ditches also and I'm usually leaning uphill out of the gauge sight line.
Current: 102 122 SZ60
Past: Original 71 72 73 86 100 102 122 123 124 125 127 129 147 149 169 383 582 682 782 782D 784 982 1000 1050 1100 1200 1204 1210 1250 1282 1415 1420 1440 1450 1535 1541 1641 1650 1710 1711 1730 1806 1810 1811 1860 1861 1862 1863 1864 1882 3185 3200 3205 7265
