Project Uncle Dick Cub Cadet 70 http://www.onlycubcadets.net/forum/s...ght=Uncle+Dick |
I'd be looking for a fuel flow restriction. Plugged screen in the tank?
Do you get good flow from the fuel line when you pull it off the carb? I don't see anything causing a sudden problem either--but the lean condition could be due to a fuel restriction.,..
Other than burning the plug up, I'm not sure what a lean will cause without broken parts that will cause a sudden failure (his plug looks lean, but doesn't look burned up to me at the angle the picture was taken). When I say I'm not sure, I mean just that. Coming from the automotive world I'm used to seeing a lean blow up parts or pretty consistently cause performance issues.
My 149 has had its Champion for at least 4 years (100-200hrs.. hard to guess) with no problems. I did buy a super fancy Autolite e-z start for it to put on the shelf for when it needs replacement. I've never tried one before in a larger small engine but my smaller small engines love them. I've had very few problems with Autolite plugs and generally put them in my power equipment. The 149 came into my ownership with the Champion so it stayed. In regard to taking pictures dirty vs. clean, I was advocating for BOTH.
I didnt clean anything when I took those pics
Also it has very good flow of gas coming from the fuel line
Maxwelhse, Merk didn't say it was burned up..... he said he can tell it's a lean condition by the look of the electrode. Which I see also. You can also see the hot-spot on the head, and around the piston. Pre-ignition. Oh, and to answer the original question, the exhaust valve looks like that because of the heat. |
So pretty much i gotta put a new plug in, ritchen up and clean my carb then my problem should be fixed? By the way ive ran that engine since march with the factory carb settings and 90 octane fuel. Also i dont like the idea of running fuel with ethanol in it and 90 octane is my only choice so should i keep running that?
i prefer 89 octane but i doubt 1 more octane will hurt.
As I've read the thread, check your carburetor and the entire fuel system over for trouble, replace the plug, and check your timing. Seems like a solid plan to get started with the rest of the diagnosis. |
