#71
#72
Hey guys,
Got the sleeve hitch installed the 169 today, I still need to install the lower hitch bracket. But if I remove the 3 bolts and remove the hitch to install the bracket, won't the rear cover start to seep oil ? I just put gasket sealer on a couple days ago and forgot to install the bracket. |
#73
You might get lucky, but I'd have a new gasket ready. The gasket is one of the few parts Case IH stores carry in stock because its the same as the bigger cubs use.
1977 1650 with cast iron lower grill housing, cast iron oil pan, 54" push-snow blade, rear blade, disc-harrow, 44c and 48" decks, Two cultivators, #1 tiller with both extensions, loaded tires, 75' weights and chains, #2 cart. |
#74
Looking good there Nickster!
About time you got it done though! ![]() ![]() |
#75
![]() Quote:
#76
As Lew would say "to much fart smelling on your part"!
#77
More like on your part. Drained the engine oil in the 169, flushed the engine out, and changed it.
#78
I got the bottom bracket installed.
#79
Here it is after a bath.
#80
Sleeve hitch.
