Old 06-27-2014, 10:57 PM
Originally Posted by Nightow1 View Post
Should receive my JD Power steering column, CC cylinder/Bracket, and My super Steer Axle next week. Then it's time to work. Hope to have it running by September. Picked up some tubing today to build the new Control handles. Need to buy a 3 Way Hydraulic diverter Valve,to T off to back for an extra set of lines. then finish my Cat0 3pt and She is done lol.
Do you mean a triple spool valve?
Old 06-27-2014, 11:20 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
No he has one of those. He meant a selector valve.
Old 06-27-2014, 11:22 PM
What's the selector valve for if he has a triple spool?
Old 06-27-2014, 11:23 PM
Nightow1 Nightow1 is offline
Yes and no, I have a JD H-3 spool valve, and I have on order a 3 Way Hydraulic diverter Valve, So we can T off the front and have an extra set of ports in back If I want them. Have the JD PS column, CC cylinder & Bracket, CC Super steer Front Axle coming this next week.
Old 06-27-2014, 11:27 PM
Rescue11 can explain it all better. I just buy the stuff lol. I know little to nothing about Hydraulics and probably never will. All I know is it will Be a beast when we are done.
Old 06-27-2014, 11:30 PM
Unless you think that you will be using the front and rear ports for 2 separate things, there is no reason for the diverter valve. I don't know why you would ever need a front blade on and be using the rear ports at the same time.
Old 06-27-2014, 11:56 PM
Rescue11's Avatar
That is the plan. Will see if he let's the cat out of the bag or not as to what exactly his plans are
Old 06-27-2014, 11:57 PM
GOOD ??
I will be using my Blade with power angle on the front, and a Gnuse bucket on the back. So in order to use both I will need a way to Divert to the back to use the Gnuse. Also we have a very large (I think I posted it a while back) Sprayer with 10' booms they will soon have 2 Hydraulic rams controlling the booms and the other one controlling the Sprayer drop it's self. So we will need it there also. But true not a normal addition for most people.
Old 06-27-2014, 11:59 PM
By WE I meant Rescue11 LOL..... If he dont have it I do so it's a trade off.
Old 06-28-2014, 12:11 AM
Rescue11's Avatar
Here is how it will be plumbed.
Scv 1: has float detent, will be used to raise either the mower, blade, blower etc... OR the cat 0 3pt. The OR comes into play by means of the selector valve.
Scv 2: to be plumbed to a set of outlets on the front and back.
Scv 3: to be plumbed exclusivly to outlets at rear end.
Reasoning? After much thinking, it has been concluded that with the type of implements and implement combinations he wants to use, this is the simplest/ most economical way to achieve fluid power in all areas.
I'm confident that it will work, only time will tell for sure tho
