Old 04-23-2010, 09:52 PM
jbollis's Avatar
jbollis jbollis is offline
Just a question.Besides the PTO, are there any advantages over this company's setup over the one from extreme ?
JOE
Sold everything but one.
Old 04-24-2010, 01:13 AM
murphycc
Guest
Posts: n/a
Put the plug back in it and tack or weld it in. If it's a clearence issue....grind it flush and tack from the interior side.....or install from the inside and weld and grind flush on the outside....just skin'n the cat....
Scott
Old 04-24-2010, 01:16 AM
murphycc
Guest
Posts: n/a
JOE
There is no comparison...I don't care what anyone says. I won't bother arguing the reasons.
Toyman's money is well spent.
Scott
Old 04-24-2010, 07:14 AM
jbollis's Avatar
Scott
I would not try to start an argument:biggrin2.gif: As you know I am gathering parts for a super build. I do not own either of these. But I do like to research a little on things so I know I am getting what I want, or the best product I can afford. So any thoughts would be nice.
Are cat 1 implements more common than cat 0 ?
JOE
Old 04-24-2010, 08:38 AM
Around my area, I've seen more Cat 0 implements than Cat 1. The Super rear hitch is Cat-0 just like the standard GT hitch.
Old 04-24-2010, 03:40 PM
toyman's Avatar
toyman toyman is offline
Ground the plug flush and tacked it from the inside. Got the rear plate done, primered and first coat of paint on it and the rear pto. Pics are coming later.
I can't comment on the Extreme hitch. (or the Ruegg for that matter as it's still sitting on the bench!) I just knew that I needed one that would work with the rear pto. I found out about the Ruegg hitch, rear pto and tiller within a day of each other. (The hitch was being discussed on another CC forum, and the pto & tiller were on craiglist)
Original Member #54
Old 04-24-2010, 04:54 PM
murphycc
Guest
Posts: n/a
JOE
Few things I think better of the Super than the GT hitch if I were to put one on a non pto tractor-
One is the rear plate is extended out about 3.5". On the GT hitch there is a hole for the lift bar to exit the plate, I find this unacceptable and un necissary. The lift arms are mounted to the rear axle as they should be so pull is NOT transfered through the rear plate to the frame and then to the rear axle which in my opinion unnecissarily adds stress to the frame and plate. Also on the lift rods there is about an inch of float with gives you about 2"+ at the end of the lift arms. The GT hitch requires the use of the tractor rock shaft to allow float and therefor you cannot utilize the down pressure the Supers have.
For my own purposes I've thought of using two '82' lift cylinders between the rear plate and the tranny cover for lift thus eliminating the lift rod altogether and eliminating all the stress on the frame. Should be easy and cheap except for the dual spool.
Scott
Old 04-24-2010, 04:59 PM
murphycc
Guest
Posts: n/a
There are 'limited' cat1 implements that can be used on cat0. For example the BEFCO 40" tiller can be ordered 540 cat1 or 2000 cat0. My 4' box is a limited cat1 or they called it the 'baby box'. My rake is a special limited 1/0 5' rake, boom is lowered for the lack of hight of the tractor. There is a 48" finish mower out there that can be converted to 2000 cat0....just a matter of cash.
Scott
Old 04-24-2010, 07:27 PM
toyman's Avatar
Good info - thanks Scott.
Here's some pics of todays progress.
Plug ground flush
bolts welded in
I hesitantly show the welds (I'm a businessman not a welder!)
Another good purchase from about 10 years ago
Spring connection
Fitting
Broke down for primer
Color
450 blower "Cub Vined" from New York to Plow Day in PA. Not bad for $250?
The BEST part of the day was the excitement and enjoyment my 12 year old daughter (toygirl) had at plow day (in the rain no less!). She wants to go next year and plow with "her" 1862:biggrin2.gif: A productive and enjoyable day!
Original Member #54
Old 04-24-2010, 09:30 PM
aagitch's Avatar
aagitch aagitch is offline
You are really coming along. It's looking great.
