Old 06-10-2014, 12:06 PM
squatch squatch is offline
Default Daggonit!
I knew I was overdue. Came home from a fishing trip Sunday and went to mow. I started the tractor and when I started the pto it started and died(PTO shut off not engine). I tried it again and same thing. 3rd time it wouldn't start. Got the tractor near the garage and the engine died. Tried to crank and no go. no lights no nothing. I replaced the main fuse and still no go. I get on it later today. Prob started with the PTO so I will to and work back from there. Went through this some time ago when getting my super sorted out. Lot's of toasted components including PTO, Relay, PTO switch and eventually the ignition switch.
Old 06-10-2014, 12:13 PM
red56turbo's Avatar
That stinks. Look at it this way, maybe it's a sign to head back and do some more fishing.
Josh
Diesel Cub Cadets...........
Old 06-12-2014, 05:37 AM
I like that idea!
I think I fixed it. It seems that once again I have had an in dash fuse holder fail. I replaced it a while back and it was not passing juice again. 12 volts in. Nothing out even after a couple of different fuse changes. I took a modern ATC style fuse holder with pigtails and spliced it in instead. Seems to be running fine now.
Old 06-12-2014, 06:28 AM
Glad to hear you got it fixed!
Old 06-12-2014, 10:57 AM
Originally Posted by squatch View Post
I like that idea!
Great news!
