Old 06-01-2014, 07:46 AM
knucklebuster283's Avatar
knucklebuster283 knucklebuster283 is offline
Default Fluid and filter
Was wondering what everyone is using for hydro fluid. TSC no longer carrys HyTrans here.
Old 06-01-2014, 07:59 AM
jimbob200521's Avatar
Tractor supply never carried hytran. Use what you want, the long and short is purists say hi Tran, everybody else says there is a dozen acceptable substitutes out there (I use travellor universal fluid). That's all I'm saying, the next time I come back to this thread it will be for the show.
-Ryan
Old 06-01-2014, 08:13 AM
This is just one of the many threads on this subject.
http://www.onlycubcadets.net/forum/s...ad.php?t=30159
Old 06-01-2014, 08:49 AM
larry03061976's Avatar
larry03061976 larry03061976 is offline
:Cho
ke: HEE HEE!
Old 06-01-2014, 11:59 AM
OffTime's Avatar
OffTime OffTime is offline
Default TSC Vs HyTran
I would like to post some observations and hopefully I can keep my opinion low key.
Some on here swear by HyTran saying it is the only oil that should ever be put into the hydro of a cub. Others are more than convinced that TSC premium hydraulic oil (or other premium brand X) meets hytran spec. If you look at a bucket of TSC oil carefully, it does not say that it meets HyTran spec, or JD spec or AC spec or any other spec. It states that it is "Recommended for" use where these other specs are used. Big difference. Recommended by whom? It may meet the spec, but it may not. Is it suitable for use in a cub hydro? No question the HyTran oil is a superior oil. I can't speak for the exact spec of the oil, but I do believe that one of the major differences is the way the oils react to the presence of water. Some oils mix with the water and make it milky and others do not.
Another observation is that these hydros are not manufactured by International or Cub Cadet. The older ones are all manufactured by SunStrand. I don't know which ones are which, but some of the newer ones are manufactured by Hydro-Gear. What do the manufacturers recommend? If you go back and look at SunStrand specs, they give a spec much broader than what you find in HyTran. Hydraulic oil, ATF, most any engine oil. It doesnt matter much. Most oils (not gear oils) meet SunStrand specs. Some people are using 5w-30 engine oil in sunstrand units with excellent results. So you decide if TSC hydraulic oil is suitable for use in your cub.
As to the filters, I wouldn't put on just any junk filter, but I am not opposed to using aftermarket if it is good quality. I personally like Wix filters. They are a high quality filter. The Wix filter number is 51410 for the IH built and the CCC built tractors. Napa Gold filters are also manufactured by Wix. The Napa number is 1410.
I hope this helps someone and I hope I haven't offended anyone. Have a blessed day.
Matthew B
1972 129 w/hydraulic lift and head light option soon to be repainted
Old 06-02-2014, 07:28 AM
dbuck dbuck is offline
Smile
Very well stated. In my CC149, Hy-tran and the CC filter has worked for 40 years, thats ggod enough for me.
Old 06-02-2014, 09:10 AM
o---o o---o is offline
[Hijack] My dad gave me his old 1541 and it has never had the trans/hydraulic oil/fluid changed in the 12 years we've owned it.
Just wondering if its easy to look at and figure out how to change it? Any tips and tricks? Tutorials? Link to a maintenance/owners manual? Is 7 quarts the correct amount? [/Hijack]
Old 06-02-2014, 09:55 AM
12 years with no service, OUCH.
Link for manuals
http://manuals.mtdproducts.com/mtd/Public.do
Warm it up, jack up the rear, remove the drain plug at the bottom near the front of the trans case with a pan that will hold 2 gals. Remove the filter. Replace the filter and fluid. You fill through the dipstick tube under the seat.
Old 06-02-2014, 11:56 AM
Welcome to OCC! It's definitely time to change the fluid.
Old 06-02-2014, 07:13 PM
kostendorf's Avatar
This is what I just spent 72 dollars on...
