Old 05-20-2014, 08:09 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
Originally Posted by dbuck View Post
Thank you Guys for your replies. I have a few jobs in the shop to get out before under taking this project. I am not interested in going the stator route, If possible it will stay battery ignition. Does anybody know if the flywheel has the indentation for the ring gear? There is no pop out for the gear starter on the shroud, so that being was there any difference in the overall dia. between the gear starter and the S/G flywheel shrouds? Thank you for your time.
there is no place to put a ring gear on the flywheel. the ring gear shroud is just a tad larger in a couple spots but should fit in a 149 with no issues. you could probably take a die grinder to the bearing plate to notch it for the starter if there's none there if you don't want to change it and you don't need a stator for charging. you won't weaken it. you will need the shroud with a hump and a flywheel with a ring gear. installing a stator does make for a clean installation. if you are thinking of using an electric PTO make sure the block has the holes to bolt it on.
Old 05-20-2014, 11:01 PM
OffTime's Avatar
OffTime OffTime is offline
Originally Posted by dvogtvpe View Post
. . . . you don't need a stator for charging.
If you don't use a stator for charging, the only other option is to mount some external battery charging device, such as an alternator. I guess a guy could just have no charging device, and just charge up the battery in the garage between uses. What a hassle. I believe, like Jon already stated, you will have a donor motor that will give you a bearing plate, flywheel, stator, shroud, starter, and possibly even a voltage regulator which you will also need. Like I stated previously, my 129 was converted and it all fits, barely, so it will also fit a 149. From the new engine mounted VR, you will need a single wire to go to the load side of the amp meter.
Matthew B
1972 129 w/hydraulic lift and head light option soon to be repainted
Old 05-21-2014, 12:52 AM
Matt,
I had to read Don's post twice. Look.
He was saying IF you don't need a stator for charging, not saying that he didn't need one. I read it wrong the first time too.
He went on to say that a stator is a cleaner set up. And, I would agree.
Thing I'm curious about on your 129 Matt is the rod for the PTO. Does it clear the starter? Or did it get modified too?
If it were me, on a 1X9, and I was going to the trouble to change the motor to an AQS, I think I'd just put an electric clutch on it too. Why not.
Old 05-21-2014, 01:07 AM
OffTime's Avatar
OK, so you are right. I read it wrong. Sorry.
The PTO linkage clears the starter just as well as it cleared the S/G. The starter is slightly lower and back towards the flywheel a little, but not as much as you may think. The link is original.
I've thought about the electric clutch, especially since this tractor needs to be rewired in some kind of bad way, but the mechanical clutch works great, and if it should ever need to be rebuilt, I would probably rebuild it with the double springs for extra clamp load just for any how. This is cheaper to boot.
Here I am hijacking someone else's thread.
Matthew B
Old 05-21-2014, 08:50 AM
dbuck dbuck is offline
Smile
Thank you Guys for all your replies. After doing some research and checking the prices on what new parts are still available. As I have no donor engine and unless I can find some good used parts/another K-321 that needs rebuilt and is set up for gear drive starter, this project is not going to happen. If it does happen you have conviced me to go the stator route. Matthew, hi-jack the thread all you want, this is valuable information. As for the E-clutch. I will pass as I just recently rebuilt my clutch and it has the double springs.
Old 05-21-2014, 10:10 AM
OffTime's Avatar
A donor engine could be a K-241, K-301 or a K-321. All have interchangeable pieces as far as these components are concerned.
Matthew B
Old 05-22-2014, 11:36 AM
Smile
Thats good to know, now I have three options for engines.
