Old 05-14-2014, 07:52 AM
Originally Posted by alyakhim View Post
I came up with a lighter spring and installed and at least it goes up and down now although its running at a lower working pressure. I found a dealer out of the united kingdom and I have a spring on order. They still manufacture replacement springs over seas. As far as replacing the entire unit for a faulty relief valve spring, that is unnecessary as I am a journeyman mechanical technician and certified machinists. I troubleshooting hydraulic systems everyday. I could be considered a hydraulics and pneumatics expert. If I were to change an entire pump unit for just a faulty relief spring my fellow journeyman would chastise me. Thank you for your help gentlemen.
Congrats on fixing your pump. I agree with what your doing, why change the whole pump when it only needs a spring. Beside that it's a lot less work to just replace the spring.
Old 05-14-2014, 11:49 AM
I agree!
Old 05-14-2014, 07:37 PM
alyakhim alyakhim is offline
Somebody that owned it before me had the absolute wrong spring it was a 5 lb spring instead of a 36 lb spring.
