Old 05-03-2014, 05:01 PM
DarwinsFlinch's Avatar
DarwinsFlinch DarwinsFlinch is offline
Default 129 Gets Some Love (Refurb)
Found some drops of hydro on the floor under the 129, so I ordered a new cork gasket. An easy split, some cleaning and a bit of Permatex later the job was done.
Original
Original
As I got down to re-attaching the pump, the close look at the dirt and rust from eight years together made me feel a bit guilty, so I've decided to give the girl some love. More project pics to follow soon.
Old 05-03-2014, 07:53 PM
This tractor takes some serious abuse over the weekends. Hauling over hills and through creeks regularly. I guess I've ignored the frame a bit long (8 years). Not looking to restore it to new, but looks like a wire wheel and some primer/paint is in order.
Original
Original
Original
Old 05-03-2014, 08:51 PM
Looking good! A few I need to do the same thing too!
Old 05-03-2014, 09:27 PM
Back and forearms are killin' me and it was absolutely worth it. Still plenty of bumps and gouges, but they are all protected now. Not going to mess with the front axle at this point.
Original
Original
Original
Old 05-03-2014, 09:35 PM
You are making great progress!
Old 05-03-2014, 10:25 PM
Looks great! Keep up the good work.
Old 05-03-2014, 11:07 PM
On a roll so I got into the steering tube. Filthy as expected so gave it a good cleaning. Added three bolts and nylocks to keep the tube from separating from the steering box. Somewhere I read about using rivets but I'd like to be able to take it apart if need be without drilling. Plus, rivets cannot be tightened if they work loose for some reason. Primed, painted, end of evening.
Original
Original
Original
Original
Old 05-04-2014, 08:32 AM
You are definitely cruising on it!
Old 05-04-2014, 12:58 PM
So, for the eight years I've had the 129, there has been no decal/insert on the steering wheel. When I bought it, the hole in the top of the cam was plugged with dirt and I saw no reason to fool with it since it added a bit of protection there (click images for large).
Finding out that it led all the way through the shaft to a hole drilled leading into the steering box changed things. With no protection over it at the steering wheel, I could just see water and crap running down into the box and screwing up the works. So I tapped it and added a grease fitting... fill it with grease and protect everything below.
While I was cleaning up and feeling all proud of myself, I accidentally discovered that Wal Mart sells an after-market part that fits the stock 129 steering wheel perfectly! A nice snug fit and clears the nipple as well.
Cheers!
Old 05-04-2014, 01:12 PM
Looking good, keep up the good work.
