Old 04-30-2014, 07:47 AM
Originally Posted by leeave96 View Post
Sam,
You're doing the Lords work fixing that Snapper...
Speaking of filthy tractors, take a look-see at this thread:
http://www.wheelhorseforum.com/topic...p-a-new-horse/
I've never seen a tractor with so much caked up dirt, grease, etc on it - LOL!
Btw, what do you have in mind for the sickle bar you got with the 149? Use it, restore it, sell it - just curious.
Looking good,
Bill
Nasty WH. Plan for the sickle is to mount it on the 1641 and use it to cut along the edge of my pond and a couple ditch's.
Old 04-30-2014, 12:25 PM
sawdustdad's Avatar
I bought some brake pad material from Mcmaster but have not used it yet. Might try it next time... I imagine that there isn't enough heat generated to soften the epoxy bond? Is there a preferred type of epoxy? (assuming slow set for max strength. but wondering if jbweld or another adhesive would be better than plain epoxy.)
Old 04-30-2014, 01:27 PM
105_Tom's Avatar
105_Tom 105_Tom is offline
Looking really good, Sam! I see the 149 also still has the float lock-out pin in place. Flip it around and you can pick the front of the tractor off the ground with a snow blade attached, and you'll be able to put some serious down-pressure on that tiller you're gonna hang off the rear!
Tom
105, 149 w/44A, #2 & #4 carts
782 CCC Red w/44C
1512 Smoker w/50C, 450 Blower
2072 w/60" Haban
IH/Lawnboy 3322 Pusher, Scag TT 61"
JD 455, X495, Kubota 2150, Gravely 450, 812
Old 04-30-2014, 03:22 PM
Tillers are attached to the lift pin with chains. Plus, they dig. No down pressure needed.
Old 05-01-2014, 10:59 AM
Sam,
How thick were the brake pads you removed and how thick are the new ones?
I'm looking into the brake pads on my 126 and have a good 1/8 inch of pad - but no brakes!
Were yours worn all the way down to the metal the pad sets-on?
My pads were almost down to the steel, new pads are 3/16" thick
Old 05-01-2014, 11:01 AM
I used JB weld on this set. I used some other stuff on the last set. Forgot what it was. They don't get hot at all.
Old 05-01-2014, 06:16 PM
Pics of the re-lined brake pads. Had to sand them down just a bit. Belt sander worked just fine for this job. Also found a replacement for the PTO turn buckle at TSC that is the same size as the OEM Cub part, TSC part number 3550591 listed as a 1/4X7 turn buckle, it's $2.29. Got the choke cable freed up with some Power Blaster. So made a little progress on the 149. The VR for the red turd showed up today so it will be getting evicted from my shop tomorrow. Best part of the day was killing grass with the 2182. Ye Hah!
Old 05-01-2014, 07:36 PM
MinnesotaCadet's Avatar
Lookin good can't wait to see how it turns out.
Connor
Old 05-01-2014, 07:44 PM
Looking good Sam.
Old 05-01-2014, 11:02 PM
OffTime's Avatar
OffTime OffTime is offline
Smile
Sam, it looks like you play my game. I just had to replace the turn buckle on my 129 Monday of this week because the old one stripped out on one end. My local Do-it-Best hardware store fixed me up for something like 2.49.
Looks like you are doing a wonderful job. Keep up the good work.
Matthew B
1972 129 w/hydraulic lift and head light option soon to be repainted
