Old 04-25-2014, 09:41 PM
elkhound elkhound is offline
Default 127 transmission
Hi everyone new here , can any one help me find out how to adjust my speed control on the 127 it creeps in "N" and it will not stay at 1 speed ,it kicks into wide open without touching anything all I can find in videos is for the 129 which has a removable tunnel the 127 doesn't come off,the handle moves very freely I would think it should have some sort of friction on it.All help will help a lot because you can mow with it like this ,all I did was rewire and paint it and change the filter and fluid ,I don't know how it was before since I just got it and it didn't run before THANK YOU ALL.
Old 04-25-2014, 09:47 PM
mmzullo mmzullo is offline
Default Manual section
Look in the manual section
Old 04-25-2014, 10:05 PM
Welcome to OCC! Good luck with your 127.
Old 04-28-2014, 09:48 PM
If you have or suspect that you have trunnion problems with your Cub Cadet hydro, start by going here.
http://cubfaq.com/hydrolurch.html
And then here.
http://cubfaq.com/trunionrepair.html
More information here.
http://www.onlycubcadets.net/forum/s...ead.php?t=4635
There is a lot of good debate here.
http://www.onlycubcadets.net/forum/s...ead.php?t=5495
After you have fixed your trunnion your forward-reverse lever and foot pedal may be out of wack, so go here.
http://cubfaq.com/neutraladjust.html
Personally, I see no need to add extra metal pieces to the square hole, unless the ends are worn crooked. I have never had this problem with any that I have fixed. So I simply weld the slots in the corners and then file them back square again.
This is the "stock" information that I post for this question IIRC someone said that one of the links is dead.
To preform these repairs the transmission and rear end must be removed from a Narrow Frame tractor.
Old 04-29-2014, 06:36 AM
Welcome to OCC!
