Old 04-18-2014, 09:42 PM
Darrell Darrell is offline
The post i was talking about i think is titled 582 Command Swap. There are other posts also , do a search for Command Swap.
Old 04-21-2014, 10:38 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Thanks, Darrell! I have found alot of very useful info.
I did pick up the motor on Saturday. Then did some yard work. Sunday I cleaned it up, fired it and checked compression(160 both sides). There was quite a few acorns and stinkbugs hiding behind the tins. There was a broken exhaust stud that I spent about 30 minutes trying to remove. Just couldn't get a grip By then it was time to do some mowing
Took it to work today and using my handy Craftsman screw extractors, I had it out in 2 minutes! Ran a thread chaser into the head and stuck a nused one in. Next weekend it should be bolted in and ready to wire it up
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 04-21-2014, 11:14 PM
Donovan M.'s Avatar
Looks like its going great!
Donovan:
62' Original-fenders
Old 04-21-2014, 11:42 PM
Nice Command, Travis!
Old 04-22-2014, 08:03 AM
Leadslingingdaddy's Avatar
Dang how did I miss that one!! : - )
Old 04-22-2014, 08:48 AM
Sam Mac Sam Mac is online now
Looking good!
Randy you have enough Command's LOL
Old 04-22-2014, 09:31 AM
Shrewcub's Avatar
Thanks guys!
Sam, check your email.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1961 IH Cub Cadet O
Old 04-22-2014, 10:23 AM
Just did and sent you a better address to contact me.
Old 04-27-2014, 01:58 AM
Shrewcub's Avatar
Well I made some progress on the repower today. I set the motor and firewall in and checked the fit. The air filter is tight but it clears. I cut out the rear of the cover to allow for removal.
http://www.onlycubcadets.net/forum/s...8&postcount=16 I used this thread for locating the holes to mount the engine. Drilled the holes and bolted it in.
I installed the trans adapter from Sam Mac and got the measurement for the drive shaft length. Everything lines up square and straight. Got the shaft cut, now I just need to get it welded. The fan is a hair to close to the hydro filter. I will have to shim it forward. I was hoping the NAPA filter would have been a little shorter than the IH one How long has that been on there!!
I tore into the 2000 wiring harness tonight and removed most of it. I hope to get it wired up tomorrow. I ordered a combo volt/oil pressure guage and I am going to use the CAT hour meter that was in my 2072.http://www.amazon.com/gp/product/B00...A22EFNA0N49HYP
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1961 IH Cub Cadet O
Old 04-27-2014, 07:53 AM
Looking good Travis!
