Old 01-31-2010, 11:53 PM
Thanks John! My buddy installed it on the tractor, before I got it. The stack has been on there for five years now.
Old 03-09-2010, 08:18 AM
dads70's Avatar
dads70 dads70 is offline
Default Stacked pics
after seeing ACECILS 100 with a cool stack thats for me.... plan one on my lil 70 as well looked this am and i can make a 1/2 sq stock brace and bolt it to the frame under the elbo and it will support the stack pipe love the look and seeing the flapper poppin as its runnin...agree gotta be careful with limbs catching it but i keep my cubbs out of the trees
Old 03-09-2010, 03:45 PM
Jeff122's Avatar
Jeff122 Jeff122 is offline
My cousin, a third generation dairy farmer, always mounts his rain caps (flappers) facing him. (backwards) He gets a lot of flack from people that it's wrong. But when he's mowing the back swath, he never gets caught on the low hanging branches. Sometimes it pays to go against the grain.
Old 03-09-2010, 04:37 PM
camarokidz28's Avatar
Default Stacks on my 106 puller
and 147
and the wheel horse
Denny
Original Member # 389
Saw It
Wanted It
Had A Fit
Got It
Old 04-09-2010, 09:19 AM
Jeff122's Avatar
Default Finally
As last, I got my stack put onto my 122. Should have had a better back ground for taking the picture.
Old 04-09-2010, 11:12 AM
Amigatec's Avatar
Amigatec Amigatec is offline
Now you need to fire up the BBQ and invite us over!
Pat Benner Haskell OK
Old 04-09-2010, 12:05 PM
Attachment 2969
Forget the stack check out those wheel weights!. What the heck do you do with your 122? My stack comes out the other side.
Old 04-09-2010, 02:41 PM
dyt4000's Avatar
dyt4000 dyt4000 is offline
Took my stack off...too many trees...
Co-Founder
You only need two things in life...duct tape and WD-40
If it's stuck and needs loosening, use the WD-40.
If it's loose and it's suppose to be stuck, use the duct tape.
Old 04-10-2010, 02:23 PM
c02cutter's Avatar
c02cutter c02cutter is offline
I love that mounting plate, nice piece of work. Love all the stacks pictured here, now for my 1200 stack... Gotta think on it, but will happen soon.
Old 04-12-2010, 01:41 PM
Jeff122's Avatar
Methos:
Don't let those wheel weights fool you. They're home made by using sonna tubes and concrete. They only weigh about 35 lbs. each. They look heavier than they are. So far, I only snow plow and haul fire wood. The sleeve hitch goes on this weekend and I hope to order a plow soon.
