Old 04-01-2014, 04:28 PM
Default Gas vs diesel, simple question
Do the gas engines have the same size pto pulley and mower deck pulley as the Kubota diesels?
What is the recommended engine speed to cut for the diesel vs gas?
Old 04-01-2014, 04:36 PM
Which tractor? All the tractors in a series used the same size PTO pulleys and deck pulleys.
WOT just like always.
Old 04-01-2014, 04:43 PM
Use the 82 series as an example.
Does the Kubota diesels turn as many rpm as say the gas Kubotas or Kohlers?
Old 04-01-2014, 05:06 PM
All the '82 (Not the red '82's though) used a 6" PTO pulley.
All Cub Cadet tractor engines are rated at 3600 RPM. Gas, diesel, Kohler, Kubota, Kawasaki.... ALL engines.
Old 04-01-2014, 05:36 PM
That's what I thought, wasn't sure. Thanks.
Old 04-01-2014, 07:15 PM
Yep, what J-Mech said. Any tractor above serial number 821,060 (1992 & newer) use the 6" pto and below that they use the 4.6"
Old 04-01-2014, 09:31 PM
Inactive Member
So how about the 982? Same size pulley or different RPM's or? Can I interchange my haban deck from the 982 to the 2072 without any pulley size changes? Thanks!
Old 04-01-2014, 10:41 PM
mpfeiffer mpfeiffer is offline
Darrell - You can switch your white haban decks between all of your supers 982,1572, 2072 The pto belt is the same size, and all the deck hangers are the same.
Old 04-02-2014, 12:42 AM
That is correct.
