Old 03-21-2014, 07:12 PM
thomas 1863's Avatar
thomas 1863 thomas 1863 is offline
Default Cub Cadet 123
so i did a hrydo oil change last winter because it froze on me due to the moister in the oil after i did it i had to make the gasket due to the fact that the one i bout got thrown away but after i cut it out and put it on and filled it up it always leaked well this winter i was using it to plow with due to my 127 being down and went to use it one day and it would not move i think it was out of oil so i put what oil in it that i had and it wasn't much so i left it sit pulled it out today to change the gasket and oil and i saw that one of the middle bolt holes was cracked but there is still some threads that give a good bite is this what was causing my leak i also go less then a gallon out of it when i drained it what if any thing can i do about this
Old 03-21-2014, 07:25 PM
Yes that is the cause of the leak, you can try jb weld around it.
Old 03-21-2014, 09:49 PM
cjrolke cjrolke is offline
I know this will not be a popular answer but on my 123 I used a permatex gasket maker to seal the rear cover. I would think that you could use it atleast around the area that is cracked to help seal it more
I would try the jbweld idea as well ( I actually used this on my 123 to fix a hole in the suction tube ) and it has held up all winter
Old 03-22-2014, 12:10 AM
gota love when stuff brakes in the middle of winter
Old 03-22-2014, 12:13 AM
i might try filling the bolt hole with prematex and then run the bolt in to it that should fill in the cracks
Old 03-22-2014, 01:00 AM
That most likely happened from not torquing the bolt properly or a bolt that was to long and bottomed out.
Old 03-22-2014, 01:36 AM
well i dont rember if it was like the last time i was in there but i did have to long of bolts in it then used a nut and washer to tighten the the cover but i did not turn the bolt tight when i put it in i tightened the nut to the cover
