Old 04-05-2010, 12:28 AM
nickvanorman
Guest
Posts: n/a
Default Starter Generator help
Hey,
I purchased a used starter generator off of ebay recently. it came in the mail today so i took off my old one, mounted the new one and it started turned over the motor well, but it would not start. i am wondering if there is a process you must go through when changing out starter generators? can someone help me please.
thankyou,
Nick V
Old 04-05-2010, 03:20 AM
ajgross ajgross is offline
Inactive Member
I think your problem lies elsewhere. The starter shouldn't cause it not to start if it's cranking the motor over.
Old 04-05-2010, 10:38 AM
goat_poker's Avatar
goat_poker goat_poker is offline
I just went through a bunch of generator problems (search for my thread titled "127 charging issues" ) and my cub would still start. I think the previous poster has it right with the problem lies elsewhere. If you have spark, I would look at the fuel system next.
Old 04-05-2010, 10:58 AM
If the S/G is doing what it's supposed to be doing, why do you suspect it as being the cause of the engine not starting?
Old 04-05-2010, 03:14 PM
nickvanorman
Guest
Posts: n/a
i have reason to suspect its the starter generator because i put the other starter generator back on (that starts just does not charge) and it fired right up. i noticed last night also, that one of the terminals on the starter generator was loose and completely stripped. is there a way to change it? this might be what is causing the problem.
Old 04-05-2010, 03:50 PM
rmunro's Avatar
rmunro rmunro is offline
That happened to me. Turned out the armature in the S/G was shot. Drew so much (probably short) There was no amps left for the ignition to work properly.
Roger,,109,1450,1210
Some Days all You Can Do Is Hang On!!!
Old 04-05-2010, 03:59 PM
goat_poker's Avatar
There's a video on you tube of a guy taking apart a delco-remy generator if that's the kind you have. Not the best video but it might help you figure out how to get at the terminals.
http://www.youtube.com/watch?v=1XDs9...eature=related
Old 04-05-2010, 05:10 PM
A couple of months ago I had a terminal that was broken off, the attaching wire went to one of the field coils inside. I took it (the terminal) and the coil out, made a new terminal and had my brother silver solder it to the lead on the coil. So far it works just as it should.
Old 04-05-2010, 05:35 PM
If it's the armature terminal that needs fixing, I'd braze it instead of soldering it. This was at the recommendation of a good S/G shop; they said that if the tractor started hard or otherwise needed cranking for longer than a few seconds, enough heat could be generated to melt the solder.
Old 04-06-2010, 08:27 AM
My experience is:
Regular solder melts approx. 750* where silver solder melts about 1200* and up.
So it acts more like brazing rod but tins/sweats easier. it would be difficult, but not impossible to braze a wire to a terminal.
I have had excellent success using silver solder.
again, just my experience.
