Old 04-03-2010, 10:55 PM
maplekid maplekid is offline
Default Doing the valves on a cub 149
My cub 149 needs new valves. How hard is it to do the valves on a kohler k321. My uncle has all the tools to do it and there is a mashine shop down the street that I will have plane the head. I need to do them soon so I can start tilling gardens with it. Thanks
Cubs 149 worker 125, 102, and 147 projects
2 blades, snowblower, soft cab, wheel weights, brindly plow, disk, 4 yard trailers, 2 sleeve hitches, tiller, scoop tote, and tow behind york rake
Old 04-04-2010, 01:11 AM
murphycc
Guest
Posts: n/a
Is the motor out?
I'm having a couple of jugs on a twin I just blew yesterday done and the last quote I got IIRC was $80 for the two. That valves ground, guides installed, lapped, and valves installed. So maybe $50 if you throw the motor down on their bench.....worth every penny to me.
Scott
Old 04-04-2010, 07:37 PM
Mike1450's Avatar
Mike1450 Mike1450 is offline
I just had my 1450 K321 block done, the valve job part was $36. Valve ground and lapped, guides were good.
