Old 03-03-2014, 12:53 PM
rdehli rdehli is offline
Default Cat 0 on 1862
can you put a cat 0 hitch on an 1862 ? will a cat 0 from a 82 series fit???
Old 03-03-2014, 01:00 PM
Probably with some fabrication, but if it would bolt right on, CCC would have listed it as an option. They don't, so the short answer is no.
Old 03-03-2014, 01:13 PM
Sam Mac Sam Mac is online now
Xtreme makes a cat 0 that fits the 1862
http://www.xtrememotorworks.com/Part.../CC-03-001.htm
Old 03-03-2014, 01:21 PM
I did not realize Aaron had a hitch that was for an 1862! Cool!
I learned something today.
Old 03-03-2014, 01:38 PM
looking at the pics on Aarons site my current hitch from a 782 should work ,except the lift arm looks to be different.
Old 03-03-2014, 01:52 PM
Give it a shot, for all I know it may be a bolt on. Keep us posted.
Edit:
I just did a little digging around on parts tree the 782 used a model 388 3 point and parts tree says it also fits the 1860 so my guess is that it will play on the 1862. This is the parts pic
Old 03-03-2014, 02:13 PM
Got to buy the tractor first. but will keep ya posted
Old 03-03-2014, 03:42 PM
Mcamp Mcamp is offline
I think the 82 series cat o should fit the 1862.
Old 03-03-2014, 04:27 PM
Hey, I was doing a little more digging on this. Apparently, the 389 Cat 0 hitch was an option for the early 1862's. Serial numbers 800,000-821,059, but it wasn't for the later serial numbers. Don't know why..... But the tractor frames changed part numbers. Sooooo...... It may depend on what serial number tractor you get.
Old 03-03-2014, 05:28 PM
I bet the later ones have the deck height adjusting rod that comes out the back. I have seen an 1863 with a cat 0. It should fit.
