Thank you. Now I have to get the tractor back together. And thanks for the other information regarding the mounting and machine height checks!! I should throw her on the 109 and see what she does
The belt width is different (narrow on a 109) and that is a special pulley on that blower. I don't think it will be that big of a deal mounting it on the Super. You may be able to cut across the front bracket and add a piece of flat steel lowering the guide and reducing the angle of the shaft both at the same time, then just use a longer belt.
Guys
I moved this to the implements area. Good luck with the blower.
Here's a link to a guy who mounted a 364 on a super - http://mgonitzke.net16.net/
