Old 01-31-2014, 01:27 AM
EarlJ's Avatar
EarlJ EarlJ is offline
Default New engine..
I just bought a 20 hp Onan from a guy in Indiana. I initially was thinking to get it running and resell. But after some contemplation I am thinking to build a plow tractor around it. So now I am seeking some ideas, I know nf tractors aren't wide enough to support the engine. Has anyone stuffed a twin into a nf? I'm not a fan of the wf look, is there a series that would be fairly easy to get it in? I am kind of liking on the red cubs a little.. I am open to any and all suggestions.. Thanks in advance..
126 in surgery with weights, spring assist, 3 point and sleeve hitch
100 with woods finish mower and rear lift,
Nice 125 with super nice sweepster, 1782 Super Diesel,
1650,782D in surgery, 102 parts tractor..
3 Brinley plows, Brinley cultivators , rear scrape blade, front plows and custom built bedder attachment.
Old 01-31-2014, 02:57 AM
cubby102's Avatar
cubby102 cubby102 is offline
The 82 series came factory with twins... as far as I know quietline and wide frames are pretty much identical to each other in that area.... a narrow frame can be done but there would be alot of cutting and welding
Old 01-31-2014, 07:26 AM
I would stuff it in a 82 series Earl. Either a NF or WF you will be doing some hacking!
Old 01-31-2014, 10:47 AM
Or a cyclops. Same frame as an 82.
Old 01-31-2014, 12:25 PM
I agree with Mike & Jonathan. You can't go wrong with those series of cubs.
