Old 01-29-2014, 11:18 AM
Bob95065 Bob95065 is offline
Default Quietline tank outlet hole size
The 1450 I bought 1 1/2 weeks ago had a brass fitting screwed into the bottom of the tank where the grommet and valve should be. Does anyone know what size the hole was originally? I want to fix my tank with a new grommet and valve but I don’t know if the PO drilled out the hole to get the brass fitting to work.
Thanks,
Bob Elliott
Old 01-29-2014, 08:04 PM
The grommet is only like $6. Buy one and see if it fits. If it doesn't, then you have a new one for the replacement tank you'll need.
Old 01-29-2014, 08:14 PM
I have an extra one...where are you?? It is .5"
Old 01-29-2014, 08:21 PM
More than likely if it has been made bigger, with a drill,you will need a new tank.
Old 01-29-2014, 09:26 PM
Thanks, i'll measure it when I get home.
I am in Felton, CA
Old 01-30-2014, 04:55 PM
Well if you need it let me know, youll have to pay the shipping...there were 2 sizes of filler holes w/ caps also on the quietlines
