Old 01-25-2014, 10:51 PM
gophred's Avatar
gophred gophred is offline
Default Another steering wheel puller
So I was reading the threads on wheel pulling and starting to rumage for peices and found this bearing puller. I was able to set it under the wheel. Then I used a normal wheel puller set with 2 arms and it hooked into the grooves on the bearing puller. It popped off pretty easy. I got the box opened and degreased and it all looks good even the follower. Wondering what is going to go wrong tonight, although I did toast the decal, which resembled parchment. This is my sons 129 and there will be heck to pay when he sees that
Gophred
2 - 1811's with 50C decks, one mows the other is waiting on deck, 129 (my sons retromod)-, hydro lift, custom 3 pt with a trailer ball , foot pedal speed control, used for trailer hauling. 129 (mower) 42" deck, foot control, 1810 with 44C - next in the slow death march of mowing the camp. a few 1200 series parts rigs. 2017 Kubota b2650 loader mid mower.
Old 01-26-2014, 09:50 AM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
I used to use that method. it works pretty good. the air hammer method is the quickest though
Old 01-27-2014, 09:02 PM
jbrewer's Avatar
jbrewer jbrewer is offline
I'm convinced that NOTHING short of the red wrench will get the wheel off my O.
I've used Matt's puller (with the oak blocks) and gotten the hub so hot the spokes scortched the block.
No go
I've marinated the thing in PBblaster
No Go.
I've rattled at it with an air hammer
No Go.
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 01-27-2014, 09:13 PM
No go
No Go.
No Go.
Get some KROIL and try that. KROIL works much better in penetrating that PB Blaster.
Old 01-27-2014, 10:28 PM
I've started to use the the air hammer method and swear by it, putting a 5/16 bolt down in there not to mushroom the actual threads. I will never use another method, works amazing.
Also, that bearing splitter tool works good and OTC makes the other half that works in conjunction with it as well.
Old 01-28-2014, 07:11 AM
X2! Kroil is some good stuff!
Old 01-28-2014, 09:37 AM
nikster's Avatar
nikster nikster is offline
My feeble mind does not comprehend?
NIK,
