Old 01-24-2014, 11:23 PM
Bob95065 Bob95065 is offline
This doesn't look good. I think this rim is done. When I removed the left wheel the bearing fell out. I think that means I need a new rim, correct?
The engine was easy to remove because the 2 forward bolts weren't't there. Lower ISOs shot!
Left brake linings
Brake linings 1/16" thick. Replace?
Old 01-24-2014, 11:27 PM
Can't see them ether.
Up to 530 and counting...
http://www.youtube.com/watch?v=xJo-gdbrUqw
This link will take you to a video I made showing the steering gearbox slop. The joint between the tube and box flexes. The whole thing is moving. I think I need a new column.
http://www.youtube.com/watch?v=qTDcuC80GCY
This link will take you to a video I made of teh front axle joint. The front axle has play when you rock it forward and backward. Do I need to shim the axle connection to the bracket?
http://www.youtube.com/watch?v=D69vY949D-0
This link will take you to a video of me rocking the spindle on the front axle. There is excessive play when you rock the spindle up and down. Is there a way to fix this?
Old 01-24-2014, 11:28 PM
I made a list of what I need to get this tractor running right:
• Mule drive adjustment lever that attaches to the right pulley
• Lower grill screen
• Headlight panel complete with screen, bulbs, grommets, emblem and mounting screws
• Muffler
• Front hood casting that the hinge bolts to
Front rim
(4) wheel bearings
Axle play???
Spindle play???
ISO mounts
• Fuel tank (I may only need the valve and grommet – I have to measure it)
• Air filter complete with engine half including three mounting screws, cover including rubber seal and rubber hose that goes to the blower housing
Steering column
• Brake safety switch arm
• Front and rear rag joints
Cooling fan
Self-aligning ball bushing on hydro end of driveshaft
• Choke cable (looking for one with a black handle that isn’t faded)
• Throttle cable (looking for one with a black handle that isn’t faded)
• Hydro lever compete with black end (not faded, decent chrome)
• Hydro speed stop
• Fiberglass dash and tin
• Hydraulic lift lever complete with linkage to valve (looking for one with good chrome and plastic)
• Key switch
• Headlight switch
• Tractor wiring harness
• Seat
• Battery hold-down, complete (2 if you have them)
• Tail lights, complete
• Brake pads, both sides
All 4 tires (non hold air,all dry-rotted and cracked)
This doesn't include going through the engine.
All my wife wants to know is how much it will cost.
I had some time after doing some yard work to remove the lift valve. It didn't want to move at first but I got it loosened up. The IPL shows 2 o-rings in the bore but it looks like there are many o-rings in there. Does anyone know if there is a write up on how to rebuild these valves?
Old 01-24-2014, 11:29 PM
Ok guys, that's what I have. Please comment!
Old 01-24-2014, 11:31 PM
Bob,
Wecome to OCC, glad to have you!
These pics you are posting are not showing up......
I used the URLs from another CC board I posted them to first. I see them on my end.
Old 01-24-2014, 11:32 PM
Is it ok to post a link to another board?
Old 01-24-2014, 11:37 PM
I don't think you can, no. It won't allow you to. Better to upload them, or link them to a photobucket account or something similar.
Old 01-24-2014, 11:42 PM
I'll try Photobucket. Stand by
Tags
#2 tiller, 1000, 1450, california
