Old 01-14-2014, 10:01 AM
sawdustdad's Avatar
Originally Posted by dvogtvpe View Post
mils , are you saying 6 or 8 millimeters or ?
1 mil = .001 inch
Old 01-16-2014, 08:14 AM
sawdustdad's Avatar
Still waiting on the camshaft shims to arrive from partstree.com. They seem to take a long time to arrive when I order from them.
Meanwhile, drilled, tapped and installed Helicoils in two of the bolt holes on the aluminum oil pan. Pretty easy job. I think I'm going to just use this pan rather than try to find a cast iron one. It lasted 40 years so far, right?
Old 01-16-2014, 09:48 AM
Probably because THEY don't have them and have to get them from another source that says THEY do. I have run into this several times w/different suppliers.
Old 01-20-2014, 05:26 PM
sawdustdad's Avatar
I am STILL waiting on the camshaft shims. But I have a question that the service manual isn't clear on. at least the pictures aren't. Can anybody confirm that these are the timing marks on the camshaft gear and the crankshaft? There are two marks on the crank, one closer to the gear. I assume that's the correct mark to align with the dimple on the camshaft gear?
Old 01-20-2014, 08:23 PM
austin8214's Avatar
Yep those are the timing marks. I use a paint pen to mark both gears so they are easy to see.
Old 01-20-2014, 10:04 PM
Old 01-21-2014, 07:55 AM
mickb72 mickb72 is offline
Default cub
Hi, Lakota Racing has cam shims in stock. Saw them on their parts board at the Columbus pull. Mike
Old 01-21-2014, 08:21 AM
dbuck dbuck is offline
1 mil = .001 inch
1mm divided by 25.4 = .03937 of an inch.
Old 01-21-2014, 12:38 PM
sawdustdad's Avatar
1 mil = .001 inch
You are of course correct, but so am I. 1 mil is NOT the same as 1mm.
Think about plastic poly sheeting (e.g., drop cloths, vapor barrier, etc) --they are labeled with thickness in mils, or thousandths of an inch as are so many other things. My blue nitrile disposable gloves for example are 5 mils. Definitely NOT 5mm thick.
Old 01-21-2014, 06:42 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
engine guys don't talk in mils, they use mm or decimal . while it is used in other industries I've never seen an engine manual use the term 1 mil referring to .001 . cause's to much confusion
