Old 03-23-2010, 09:17 PM
wshytle wshytle is offline
Default Ammeter jumping
The ammeter on my 1250 will jump to the left then go back to the normal charging position then jump back again. The battery doesn't give problems and seems to holding a good charge. I've checked for loose connections,etc but haven't sourced the problem. Has anyone had a similar problem? I'm beginning to wonder about the meter itself.
Any thoughts out there in cybercubland?
Thanks in advance.....Wayne
Old 03-24-2010, 05:18 AM
d_day2613's Avatar
d_day2613 d_day2613 is offline
Default 1250 Ammeter
Might be the Regulator/rectifier. Good thing is that it is a simple fix. Right (passenger) side of engine on the flywheel cowl. Two bolts hold it in. Unplug put new one in, plug it back in, golden. Before replacing, make sure it is tight, as it must be grounded. I've also ran a ground wire off of one of bolts to the frame to solve this problem. Had the same problem with the Quietlines before.
Old 03-24-2010, 05:22 AM
D_Ordway D_Ordway is offline
I have had a similar problem with my 1650 where the starter switch has a bad connection causing a no charge condition
Old 03-24-2010, 05:03 PM
Amigatec's Avatar
Amigatec Amigatec is offline
I just got my 129 running and when I go to full throttle the Amp Gauge goes clear past the C and pegs out. Is this normal for these?
Pat Benner Haskell OK
Old 03-24-2010, 05:10 PM
Amigatec's Avatar
The VR is new as is the wiring, I did buy a used AMP Gauge, and the S/G I am not sure of.
I will check the voltage output and see where it is.
Old 03-24-2010, 05:27 PM
Amigatec's Avatar
I will check it out.
Old 03-24-2010, 07:13 PM
Amigatec's Avatar
It appears I was sold the wrong VR again!! It's a 4 wire and not a 3 wire. It has Bat, F, L, and Gen Terminals. According to the wiring diagram for the originals the L terminal goes to the Ign Switch and then to the coil.
I have an email in to the store I bought it from.
Old 03-24-2010, 07:16 PM
Amigatec's Avatar
Here is where i bought it from.
http://ccspecialties.org/electrical.html
Old 03-24-2010, 07:17 PM
Amigatec's Avatar
I checked the voltage and it's putting out way over 16 volts.
Old 03-24-2010, 09:11 PM
d-day2613-
I changed out the rectifier and things became "golden". Thanks. It's a good thing to have several spare engines sitting around. I didn't do the ground wire thing but I cleaned the mounting surfaces well. It shows a steady charge now so I put the battery on trickle tonight to bring things up to par.
Thanks again....Wayne
