#21
I don't know... I've been making them 19.875" for a long time.
#22
Anyone have the hole locations for the NF & WF hydro driveshafts?
Thanks Jeff |
#23
Do you know how long they are?
I can check in the morning for the location of the said Hole..
#24
It looks like the NF driveshaft length is 17.52 inches , the WF is 18.52 & the QL is 18.86 ( Did I assign the correct model number numbers to the QL ? ) Thanks Lew |
#25
Jeff..
working on it. Well I have to admit my brain had brain freeze today out in the cold and forgot to do it...
#27
![]() I wore my full face motorcycle helmet clearing snow with the 125 I got from you with my QA-42 and stayed nice and toasty for the 2 hours I was working outside. No heat loss made the below zero windchill extremely tolerable. ( you lose most of your heat thru your head compared to other extremities ) Jeff |
#28
![]() ![]() ![]() ![]() ![]() This what I have Lew. From my 72.
IH CUB CADET 1450, 72, 86, 1211, IH #2 CART, IH 56" SNOW BLADE, COLLECTING CUB CADET ENGINES |
#29
These are the dimensions I used for a creeper shaft. I directly got these dimensions from the shaft in my 122. Works great so far!
Yosemite Sam's dimensions look good to johncub7172's measuring tape. I bet if you were +/- .05 (almost 1/16) it would function fine. The hole on the coupling end is probably the most critical that it doesn't interfere with the input shaft.
1966__122 Cub Cadet. Owner: Calvin, 6 yrs old Dad: Craig |
#30
Jeff is looking for the position of the hole on a hydro driveshaft.
