Old 12-22-2013, 07:23 PM
Muzzy Muzzy is offline
Default QA36 gearbox seals.
Are gearbox seals available for a QA36?
Old 12-22-2013, 11:04 PM
aldiesel aldiesel is offline
i was just looking at parts brake downs and maybe i'm reading it wrong but they don't show a seal for the QA36 they do for the QA36A??
Is the seal you are looking for between the bearings?
If this is the seal you are looking for yes you can still get them aftermarket couldn't find them OEM.
I have a set ordered and once i get them i will post the number.
Hope this helps
Tony
Old 12-23-2013, 08:13 AM
I have'nt taken it apart yet so, I don't know exactly what they are but, it's leaking at both ends.
Old 12-23-2013, 09:45 AM
I just finished a QA42A box and there are 2 bearings and one seal at the end of each shaft. So, If you are going to O/H the box you will need 2 inners, 2 outers and 2 seals.
The inners are open face rollers that should 1st be packed before installation.
I used wheel bearing grease for that as well as in the gear box itself. The seal goes between the inner and outer bearing. The outers are sealed bearings.
I chose to go with parts from IH Case instead of aftermarket stuff which would no doubt be cheaper. Here are some #s for reference. These are for the QA42 but should be the same for others, you will have to do your own research here.
Bearing #475627R91 $26.00 ea 2 req'd
Bearing #475628R91 $23.32 ea 2 req'd
Seal #485306R1 $11.48 2 req'd
Needle bearing for the adjuster bracket #387835R91 $9.35 ea 2 req'd
Old 12-23-2013, 10:15 AM
Thanks to you guys for the info. I can't justify spending that kind of $$$ on a 45 year old attachment that I don't use that much anyway.
Thanks again.
Old 12-24-2013, 09:24 AM
Well I got lucky yesterday and found a good gearbox locally for the QA36. The best part was that I traded a non working chain saw for it. The 36 lives again.
Old 12-24-2013, 09:46 AM
Great news!
