Old 12-21-2013, 10:50 AM
SS5150's Avatar
SS5150 SS5150 is offline
Default Fuel shut off valve
What do you guys recommend for a fuel shut off valve? The valve under the tank on my 782 leaks down a bit and its not convenient without removing the side panels regardless, my tractor has 5/16 from the tank to the pump but 1/4 to the carb......is that even correct itself? What have you guys used and where did you locate it in the line? Thanks.
RUN IN THE RED
1872 project
Cub Cadet Pro Z 560 L
Old 12-21-2013, 11:01 AM
cubs-n-bxrs's Avatar
If it were me I would install a inline fuel shut off valve before the fuel pump. Then all you have to do is raise the hood reach in and shut it off. I am pretty sure I saw them at lowes in in lawn and garden section and they are made by B&S. I think they are less than $10.
Old 12-21-2013, 11:10 AM
I have the same setup as Kelly and it very convenient.
Just remember to remove the screen on the shutoff valve on the tank. Then put an inline fuel filter made for a fuel pump system after your new shutoff valve.
Just my 2ยข
Old 12-21-2013, 11:31 AM
I don't think I would remove the screen, it keeps the bigger stuff out of the system, and when you take the shutoff out usually you also need to replace the gromet because it is old and cracked,and when disturbed it will leak.
Old 12-21-2013, 04:13 PM
TheSaturnV's Avatar
I had one of those cheapo red/black inline shutoffs, and while it worked I didn't like that the way I always had to grab it with two hands to open/close. Otherwise the fuel line and connections got twisted around.
