Old 12-17-2013, 12:37 PM
CTorris CTorris is offline
No. Handle was hitting frame, bent handle away from frame, now top of weld is hitting frame, see top of picture. Spring is good also, holds latch rod up tight. this is the best I can get! Is it enough?
Old 12-17-2013, 01:18 PM
That looks about right.
Old 12-17-2013, 01:22 PM
Cool! Thank You! Thank You Everybody!
Old 12-17-2013, 01:32 PM
Looks good from here. Check the condition of the pins on your plow also.
Old 12-17-2013, 01:39 PM
Pins on plow are perfectly round. It was one of the first things checked & ruled out! Plow is almost new.
Old 12-17-2013, 08:20 PM
i noticed on mine that the bottom tabs on the hitch were bent down some...5lb hammer and some carefully placed blows upward to tighten them up if theres too much slop..
Old 12-18-2013, 05:08 PM
Default Perfect!!!
My driveway is approx. 300 yards long with a 60' x 100' turnaround at the bottom. I Plowed 6" off it today with no problem thanks to you gentleman! Plow stayed on the whole time. "When in doubt go to the experts! Thank You Again!
Cly
P.S. I'm going to have to figure out another way to work my upper body muscles knee deep in snow! TY
