Was it ever...rebuilt the carbs on both the 125 and 104...seems like twice the new kits came with the wrong size jets and I didn't realize it until after I reinstalled and started working the tractors... Both stated blowing heavy black smoke and gas was pouring out the throats... Had to pull them both back off and put the old jets back in.. Once that was worked out, I mounted the plow blade on the 125...found out quick there is a fine reason for the holes in the front of the mount...that blade will fall out if they are not in there
126 in surgery with weights, spring assist, 3 point and sleeve hitch 100 with woods finish mower and rear lift, Nice 125 with super nice sweepster, 1782 Super Diesel, 1650,782D in surgery, 102 parts tractor.. 3 Brinley plows, Brinley cultivators , rear scrape blade, front plows and custom built bedder attachment. ![]() |
![]() ![]() Tell us more about the wrong parts you got? How did you discover they were wrong, can you notice the difference by looking at them or are they that small of a tollerance the naked eye can't see it? When you say its spitting out the throat - where exactly? You might be onto something for an issue I have with my 100 with a K241 spitting gas out the bottom hole of the carb on the breather side when I choke it???
Mike Ontario, Canada IH built 982, IH built 782, IH built 782 parts tractor, 100 w/fenders & lights, #4 trailer, 42" front blade, IH 2B tiller, 12" Brinly plow, Brinly cultivator, IH push mower, Sims cab, IH snowthrower, 450 blower. ![]() ![]() ![]() ![]() |
Holes on the front of the mount? Not sure what you are talking about here...
![]() Quote:
On the subframe where it turns up on the frame just ahead of the Frankenstein bolts...
I am not understanding this jet issue. Are you taking about the fuel shut off valves. Any ones I have ever changed come with a viton tip and they are matched to the seat that threads into the base of the carb. Changing them in a pair you should have no issue unless the float needs to be reset with the new parts installed. With the carb held upside down the float should be parallel with the base. If it's not that might be the fuel not shutting off issue.
149,682,1641,1711 with a 12hp in it 1 8" brinly plow 1 10" brinly plow 451 snow blower,H-48 International snow thrower 42" york rake with fold down grader blade. |
The cubs are looking good, Earl.
Ah, I understand now. I've got the pins running into the quick release then bolted it to the frame in the holes above for an added security measure. (on my snow blade.)
![]() Quote:
